Jedi EPG Xtream
Тема у розділі 'Плагины расширений', створена користувачем learn, 17 січ 2020.
  1. learn
    How to use
    Plugin is found in plugins menu.
    Plugin loads all bouquets from bouquets folders except bouquets created via Auto Bouquets Maker.
    Therefore can be used with any bouquet creating plugin not just my Jedi Maker Xtream.
    Column 1 - Bouquets
    This will load all your bouquets as found in /etc/enigma2/
    If bouquets are grouped it will load parent group. Pressing right or OK will load sub-bouquets.
    Column2 - Channels
    This loads all the channels from the selected bouquet.
    If a channel has an EPG already assigned via this Jedi EPG Xtream plugin a LINK icon will show next to it.
    Can unassign an EPG from the channel by pressing GREEN Button while that channel is highlighted.
    Column3 - EPG sources
    This loads a list of EPG sources that are defined in an editable file - epglist.txt
    /etc/enigma2/jediepgxtream/epglist.txt
    I have added in all the Rytec sources into this file, and 2 other working sources.
    If using Jedi Maker Xtream playlists, these xmltv.php sources will also automatically be added to the EPG source list on load.
    You can also use any active xmltv.php file to populate other providers.
    Other 3rd party EPGs can be added. But EPG importer cannot use https:// sources though :(
    Sources can be xml, xz, gz or an active iptv xmltv.php links
    To edit the epglist.txt file, 2 elements are required. A name and a source separated by a single space.
    The name has to be file name friendly. So use only Alpha-numeric characters and hyphens. Do not use \/.?* or spaces.
    good example:
    Rytec-News-Channels
    Чтобы увидеть скрытый код необходимо зарегистрироваться. bad examples:
    Чтобы увидеть скрытый код необходимо зарегистрироваться. I have pre-downloaded all the sources data in compact form.
    Sources can be refreshed by pressing YELLOW button or OK button if source list is empty (optional), or can be hidden by pressing BLUE button.
    Hiding the source just comments it out of epglist.txt file. It does not permantly delete it.
    Column 4
    This column only lists active channels that has EPG data. It does not list channels that are named but has blank EPG data.
    Therefore this plugin can actually be used to check your providers XMLTV file to see what actual channels should have EPG.
    Press OK or GREEN button will assign this EPG to the channel.
    On assigning it will jump back to column 2 to allow further adding of channel EPGs.
    On assigning - everything is automatically created in the background. No further saving need, just exit out of the plugin to finish.
    Navigation Buttons
    Left
    Right
    Up
    Down
    Channel up - Page up
    Channel Down - Page down
    0 - Back to top
    2 - Previous Letter
    8 - Next Letter
    EPG Importer
    Open EPG importer.
    Press BLUE button for "Sources".
    Expand "Jedi EPG"
    Select all sources.
    Save
    Press YELLOW button to manually download sources.
    How to delete all assigned EPGs and start from scratch.
    delete epg.json from /etc/enigma2/jediepgxtream/
    Останнє редагування модератором: 19 січ 2020
    marfaz та falke подобається це.
  2. learn
    Версия Open Vision: 9.3-r84 тоже отлично работает на IPTV.,
    falke та kil1970 подобається це.
  3. falke
    falke Свой человек
    Проверил плагин всё работает.В IPTV выбрал канал на котором нет EPG ,в моём случае взял Литовские каналыTV6(2) штуки, LTV7 и ещё парочку,и одну парнушку. Зашёл в плагин,там мои избранные, нашёл эти каналы,нажал ОК - 3 раза и на канале появился значёк.Пошёл на плагин EPGimport,по синей кнопке выбрал JediEPG и поставил галку на GenIPTV-,сохранил зелёной кнопкой,закачал жёлтой ,и готова
    gurasik43, kil1970 та learn подобається це.
  4. fansat
    fansat Любитель
    Уважаемый falke подскажите.
    1. В плагин EPGimport, 2 ссылки вставлены в rytec.sources.xml (одна ссылка-каналы, другая-сам EPG)
    <source type="gen_xmltv" nocheck="1" channels="http://runigma.com.ua/EPG/IPTV/channels-iptv.xml.gz">
    2. Есть ещё источник EPG
    Чтобы увидеть скрытый код необходимо зарегистрироваться. --------------------------------------
    Как в файл: epglist.txt -- добавить свои ссылки ?
    Покажите образец.
    литовские каналы в скором времени можно будет добавить и у нас
    пишите какие , добавим
  6. falke
    falke Свой человек
    fansat,взял у тебя
    <source type="gen_xmltv" nocheck="1" channels="Пожалуйста войдите или зарегистируйтесь">
    <url>Пожалуйста войдите или зарегистируйтесь
    <description>(epg by test)- IPTV </description>
    <url>http://Пожалуйста войдите или зарегистируйтесьl.gz</url>
    ты это имеешь ввиду?
    про плагин
    Jedi EPG Xtream,я бы сказал все EPG врёт
    Останнє редагування: 19 січ 2020
    fansat подобається це.
  7. fansat
    fansat Любитель
    Да -- две ссылки в моём посте:
    Покажите образец.
    прячем ссылки под спойлер
    админ
  8. falke
    falke Свой человек
    по ftp захожу в etc/epgimport, rytec.sources.xml правой мышкой редактировать. образец - пост 6
  9. MOJSEJ
    MOJSEJ Новичок
    Jedi EPG Xtream кде ето могу скачат
  10. gievih
    привет,так в 1-ом собщении есть ,а так-же в *гугл *поищите есть уже обновленые версии
    MOJSEJ та kil1970 подобається це.
  11. MOJSEJ
    MOJSEJ Новичок
    Я уже скачал но епг на ilook tv неработает што зделат
  12. gievih
    привет ,к сожалению не пользуюсь этим плагином ,возможно другие пользователи подскажут в этом
    воспользоваться нормальными плагинами , этот плагин заточен под забугорых провайдеров
  14. marco84
    marco84 Новичок
    не могу поставить epg на iptv вроде грузится epgimport но не показывает программу
  15. gievih
    хочу уточнить ,,Вы программу с етим плагином связываете(Jedi EPG Xtream ) или как ?
  16. marco84
    marco84 Новичок
    нет с epgimport скачивает программу но не показывает что не так делаю не могу понять
  17. marco84
    marco84 Новичок
    у меня openatv7.5.1 может из-за этого
  18. gievih
    бывает и плагин не грузит
    букет чем делаете?Етим плагином ?
    нет, не зависит
    Останнє редагування: 27 лют 2025
  19. marco84
    marco84 Новичок
    m3u плейлист ilook конвертировал для enigma2 в этом сайте и скинул в ресивер
  20. gievih
    конвертировали каким способом ?скриптом от ЛЕОН?
